starburster81
- Thread starter
- #16
Could I just run solder down there or would it work better with the copper?David_AVD said:Run a bit of tinned copper wire along the red path I've added.
starburster81 said:Could I just run solder down there or would it work better with the copper?David_AVD said:Run a bit of tinned copper wire along the red path I've added.
starburster81 said:Argh, why are all the circuit boards different! This is the last type, I swear
Success! Thanks again for your helpDavid_AVD said:starburster81 said:Argh, why are all the circuit boards different! This is the last type, I swear
Here you go. Link those 3 points.
Maybe scrape away those stray bits of solder at the left edge of the board.
