Hi all, anyone had experience with these RGBW controllers
http://www.aliexpress.com/item/2-4GHZ-4-zone-LED-RGBW-receptor-used-with-2-4GHZ-RGBW-touch-remote-support-wifi/1667763036.html
[/size][font=verdana, arial, helvetica, sans-serif]I think I stuffed up and ordered the wrong one from Ray. I plugged in RGB lights not RGBW lights and there is no light output. I only get 12V output from the white connection. The others range from 2.6 to 3.6v. [/font][SIZE=78%][/SIZE][SIZE=small]Should all the outputs (R,G,B and W) all measure 12v output or is the fact that only the white has enough output to light the lights and indication that this receiver is faulty or does it rely on the white in the strip to work.[/SIZE][/size][font=verdana, arial, helvetica, sans-serif] Is there any work around to get it to work with straight RGB strip or do I chalk it down to experience and have to order the RGB one? [/font][size=small]
