rPi interference on FM transmitter
TheRichardsons
Hi Everyone!
I'm pulling my hair out here.
I've got an rPi running FPP to a f16V3, and a ST-7C FM transmitter.
When I run an audio cable from the USB Audio or directly from the pi, I get terrible interference (hum, buzz, feedback.. all sorts)
When I run audio from an iPad or phone there is almost zero interference.
Any tips on how to fix this?
Thanks team!
scamper
collie
A lot of people use a sound blaster card, but I found the best solution was to make a external di pole antenna.
  • How_to_make_a_dipole_antenna.pdf
1 issue with the Pi's is that the 3.5mm audio output is actually a 4 pin plug with video on it as well as the standard audio. If you haven't used a 4 pin to 3 pin adaptor of some sort then turning off the video on FPP may give you a reduction in what could quite possibly be video that you are hearing.
B4IGO
Sydney
Oooooooh! That might explain why my Pi shuts down when i turn on my transmitter?
Grandpa Elf
Could also be a power (not enough current - voltage dropping) issue if the pi is sharing the same power supply as the transmitter?
B4IGO
Sydney
Another good thought David. They are on different plug packs though. I have a sound blaster coming so will see what that does... and when i get some time will dig into it further.
TheRichardsons
I'll give it a shot. I've noticed left is louder than right with this transmitter as well. (even when running off iPad).
