Show your layout
Juddge
Excellent - XLights is what I will be using for my controllers
So I can draw a rough layout of my house and add lights around it ? Or do I need a photo that can be converted to wire ?
Indigogyre
Journeyman Elf
Yes, You can draw something up if you want to use that. Technically you can just add props to the blank layout but it'll mess up perspective. I just took a photo of my house with my phone and used that.
Skymaster
Crazy elf
Western Sydney
If you're doing it in 2D layout, you add a front-on photo of your house, and you just draw on the lights & models etc. You could do it with a sketch if you like but a photo is usually easier.
If you want to do 3D layout, you need a 3D object file should you wish to do that. I dont, namely because my lights are roughly in the shape of the house, so I just "guessed".
I would suggest starting with the https://videos.xlights.org website - this may be a good video to start with
View: https://videos.xlights.org/xlights-gem-series-basic-layout-intro-and-tips_e39dd6ea2.html
CargoLights
You can do it either way. A photo makes it a little easier to visualize. You can also import a 3D model of your house and design in 3D, but that's a whole other learning curve.
Kent
I'm occasionally out Penrith way for work. If schedules align and you're interested, I could grab some shots with the DJI mini to create a 3d model for you. Will PM with details.
Rodney766
This is my layout, its my third year using pixels and I have been adding bits each year.
The tree on the RHS is flat and the gap toward the top is where my countdown clock is located. The circle in the centre of the layout is lights around a push to listen button.
Notenoughlights
400,000+ twinkly lights
Christchurch, New Zealand
So far what I've set up in xlights when moving over from Vixen for this year (still using vixen to sequence for this year though) it doesn't show any of the static lights that cover everything else, this is just what is hooked to various controllers. The big circles are single channel lights.
