Baf05 said:yes that's exactly what I am trying to do, I have tried the colour macro slider, but it seems to not be working exactly how I want, it more outs every thing on, then does a spin... re your issue, in the visualiser are they two trees draw at exactly the same height?
I have thought about doing that, or even trying to draw the spiral...., and was my next step in trying to get it to work, will let you know.dale82 said:Just a thought, in the Visualiser just draw 2 lines exactly the same height and side by side and use the colour slider macro. I think that should work
For me strip kept pixels equal spaced and just had to be zip tied onto frame. I found that the best waterproofing is found on strip and modules which is what I try and use now. Pixels have there place but have been a bit hit and miss with waterproofing.InTheSpirit said:Is there an advantage to using strip instead of strings? other than the ease of the build.
I did 12 trees last year with dumb RGB strings and it took forever to attach basically every bulb.
I think you way makes a lot more sense.
