im willing to give this a go.. send the app over please
bpj1980 said:here are my email settings hope this helps, i started with emails working then moved to Vixen, the Vixen Messaging will send an email back to the account you have sent it from also, great piece of software i am going to work on the SMS side tonight,
http://i.imgur.com/6Lvw2vj.jpg
grahami2006 said:bpj1980 said:here are my email settings hope this helps, i started with emails working then moved to Vixen, the Vixen Messaging will send an email back to the account you have sent it from also, great piece of software i am going to work on the SMS side tonight,
Here are some screen shots I have taken of gmail set up as well as messaging set up.
cozbert said:im also keen to give it a whirl
smartalec said:i got banned from it.. it kept tempting me not too..
i never got to see the text scrolling but i did see the nutcracker effect kick in.
suppose it's one thing..
when someone sends a message, cause we add a custom msg to the start of there's?
when a person gets warned, it is possible to have that msg an count customed?
quote " You have been banned for the night for sending inappropiate words. Thank you for watching the lights on Northridge Rd. "
this is a great app.. only issue i see is that i run vixen3 sequences off the falcon pi player
is it possible to convert your app over to the pi ?
keep up the great work
grahami2006 said:This is now the message I get. Do I need to change the SMS box to the email account. I have Vixen running. I presume I do not have to do anything with the effects in the sequence.
cozbert said:seems to work ok when i dont have a sequence running, but it overwrites the current sequence that is playing?
bpj1980 said:Hey Geoff,
I am having a similar issue to what you said, if I am running a sequence with a Display, they run over each other, I have worked around it a little bit by using launcher to start & stop Vixen Messaging when I got my own running, but stopping the program doesn't stop the VixenOut sequence so it continues for the set time, any way we can stop the sequence when the program is stopped/shutdown? that way we can launch it any time through Vixen we want, to prevent it overwriting what we have up there? just my 2 cents worth, otherwise loving it, going to look at the SMS side tonight, I have just installed the latest version you sent this evening, so having a look to see if it still over lays existing displays,
Thanks for your continued hard work,
Brad
Brad
I haven't played with the launcher, so I would be interested in how you ended up setting it up.
