I just finished putting up these light mounts that I created this year. Previously I've always tried to do something that wasn't permanent (like using binder/bulldog clips to attach to the edges of the ridge capping), but this year I decided that I'm just going do to something permanent.
So the following is what I came up with: (sorry I don't know how to make them thumbnail size or add them as an attachment)
Basically, I started with a Carinya "Make a Bracket" bracket (this one). Then I've taken a hammer to it, to bend it slightly for maximum contact with the curved nature of the ridge capping. Once they were all bent, I then spray painted them the same colour as the Colorbond Sheets (not the bottom), so they're at least somewhat camouflaged in the off-season, and hopefully have some protection against rust. I then got up on the roof and cleaned each ridge with some pine-o-clean, so I could attach the brackets to the ridges using Gorilla Double Sided tape. I never intended on using double sided tape, however when I walked past it at Bunnings (it's in the same aisle as silicone), I noticed that it said indoor and outdoor and that it's weather proof, so figured it would be worth a go. I also bought some Roof and Gutter silicone in the same colour as the roof, and injected that into the diamond holes and along the edges (first time using a silicone gun, the stuff just keeps coming out! Please don't judge too harshly).
So after all that, the above images are what I ended up with, and I'm very happy with it. We'll see how long the double sided tape will last. I have read around here that double sided tape won't last, but because this says it's weatherproof, I want to give it a go. The silicone is there as backup.
The advantage of using the double sided tape and the silicone, is that I didn't have to wait for the silicone to dry before I started attaching cable ties to the brackets. Speaking of cable ties, I made sure to get ones that said they had some "carbon additives for added UV protection", whatever that means.
The best part about these brackets is that I now get to have the LED string sit right on the top of the ridges, which satisfies my OCD very much. Hopefully they'll last more than just this season!
Please let me know what you think
