Why all the ports on a controller…
TerryK
Retired Elf
West Central Ohio
If you daisy chain those smart receivers you can get it up to 28 ports maybe 36 if you converted port 1-4 to smart and then hooked up receivers to the serial port.
Firmware updates might have changed things but my understanding is a F4v3 cannot be expanded to more than 12 ports. That is the 4 board ports and the 4 ports on each of the 2 Smart Receivers a F4v3 supports. The Falcon Specification sheet is a bit confusing on this so a question to David (Pitts) may be in order.
KStatefan
Kansas
Firmware change allows smart receivers daisy chained. I think it was v2.55 but mine are on v2.59
Skymaster
Crazy elf
Western Sydney
Just remember that the "extra ports" that daisy chaining does not increase the number of pixels you can run on the controller, or on a particular numbered port. i.e If you're going to top out at 680 pixels at 40 fps on Port 1, then Ports 9a, 9b, 9c all share their own allocation of 680 pixels as well.
The smart chaining actually reduces the total number of pixels available due to the protocol overhead. It's primary purpose is to allow remotes closer to props and power distribution.
BrianZ
Miami, Fl.
I’m actually going to add a differential expansion board onto the F4. I’d also like to connect to PSU’s together to be powered by one cable to the outlet. The 2nd is connected to the first with only the neutral and ground, correct?
Skymaster
Crazy elf
Western Sydney
If you're using the one incoming mains lead for two power supplies, you would connect all three wires to both. This is essentially how they would connect behind an outlet if you had two leads separately.
Without the Live going into the second power supply (just N and E/G), you would not get any power, it's equivalent to switching off the outlet.
I will always strongly recommend on the mains side - have someone qualified to look it over, and double check everything before connecting power.
Incorrect wiring at best would not work, at mid would damage equipment, or at worst, kill someone.
