ACL CAT5 to Screw Terminal RGB breakout PCB
AussiePhil
Administrator
Canberra, ACT, Australia
Due to some local demand I have thrown this little PCB together.
It can be used at either end of a CAT5 cable or even in some cases both ends, it will allow you to send 12 Channels, 4 x RGB groups down 3 CAT5 cables.
It can split 4 channels coming from some controllers on CAT5 out to screw terminals.
We have also included the marks so you can use your Rainbow flood RJ45 connectors and CAT5 and then break out to a normal DC controller near the controller.
Normal caveats apply to Power and current draw on the CAT5 Cable.
Phil
Harrison
I'll crack open a Bulk Buy Thread for this with the BOM, just chasing up supply for the Screw connectors as i can source them at 30% the cost of a Mouser connector.
Phil
Steve22537 said:
Can I participate in this future bulk buy if I’m not a finical supporting member?
What is a "finical supporting member" anyway. we accept all orders here.
Just a quick note
Looks like the BOM of
3 x top load RJ45 Socket
8 x 2Pin Screw terminals
will be around $2.50 Max
Note: currently all pricing discussed is in US dollars
Phil
not yet - waiting on RJ45 Sockets to arrive to confirm hole spacing as i have a new supplier and like to be sure, only then will the PCB's actually be ordered.
The sockets are on the fast slow boat from China atm.
As soon as i actual photos i will post
Phil
Great idea Phil! 8)
I will be keeping an eye on this as well. I could use a few of these myself.
Bill
Great must have box. Im in for some. Let me know when the buy is ready.
Kevin
