2 Layout problem.
Tuke
Hello all, hope everyone's new year has begun splendidly.
I have run in to a dilemma that I have had a problem resolving so I thought someone here may be able to offer some guidance.
My home is located on a corner lot so when I built my first layout it was from a frontal view of my home and I just placed my mini trees, candy canes and other props all in front of my home to sequence. I later took another image from the corner of my street to include the side as well as the front. Same channel designations for each individual prop but now the props are in their proper place so I have a more accurate representation of what the display will look like.
However, when I choose that layout and open a sequence, the house preview I get is the original frontal view image with the outline of the corner image laid within the frontal view.
I've found info on sharing layouts and sequences but nothing on how to use an existing sequence on a separate house preview.
Does anyone know and can tell me what I'm doing wrong?
It looks like what you're wanting to do is change the background image. On the layout tab click on a vacant bit of the image of your house, click on the "background image" thingy on the left and navigate your way to the image that you want.
I have the image loaded. My original preview is set as my default on the "preview" dropdown menu and the corner view is a separate view.
The problem is, is I can't get the corner image to load when I'm in the sequence tab. Everything I do keeps resulting in the corner image outline only (not the actual image) superimposed over the default frontal view.
If you right click on house preview, you should be able to select the views you created.
