Sounds like the f16v3 wasn't connected to a network when you powered it up after it has been sitting. (It will probably be something different from last year) This is due to it being set to DHCP.fired up the f16v3 for the first time since xmas and it seems to have forgotten it's ip and reverted to all 0
Sounds like in your configuration of the controller some ports are set to 1 pixel only.i then tried to do a test on some new props using the test button on the falcon but only the first pixel worked??
