Release 2017.6 released. HSV sliders on color box,
smeighan
4217 Greenfinch Dr CO 80126
Release 2017.6
Keith added HSV sliders to color box. This means you can shift all the colors on an effect after the effect has been created. Example: slide S (Saturation) and your 5 colors can be muted into pastel colors. Slide the V (Value) and you can make all colors darker or lighter. Slide the H(Hue ) if you might want to shift the actual color of all colors. Example you have 3 blues in your effect and you want to make them a little more green.
Just another option to make you never able to keep up. *smile*
Thanks Keith and Dan!
2017.6 Feb 27, 2017
-- bug (dkulp) Fix xScheduler logging on OSX
-- enh (keith) Add duration treatments to glediator effect
-- bug (keith) Include iseq files in package sequence
-- enh (keith) Add a scale but keep aspect ration option to Pictures effect
-- enh (keith) Add HSV adjustment to the colour panel ... this is applied after the effect is rendered.
-- enh (keith) Let the user turn on/off color panel reset when changing effects. This setting is not saved when xlights is closed. It also does not control the pallette itself
-- bug (keith) Fix spatial colour curves on pinwheel using old render style
-- enh (keith) Add a new sweep 3d style to pinwheel
-- bug (keith) Fix projector details not saving correctly in xSchedule options
-- enh (keith) Default color curves to the colour of the swatch (instead of black)
