Release 2018.23 xLights released
smeighan
4217 Greenfinch Dr CO 80126
Relase 2018,23 released
Thanks To Gil Jones, Scott Hanson, Chris Debenham and Keith Westley for this content release
13 bug fixes, 8 enhancements
---------------------------------2018.23 July 27, 2018
-- enh (gil) Increase DMX Effect/Panel to 40 channels.
-- enh (gil) Changed the default channel assignments for the Skulltronix Skull option so that you can set
the start channel to 1 and the Power channel will start at channel 8, Jaw at 9, etc.
-- enh (gil) Added the default Node Names for the Skulltronix Skull option.
-- enh (gil) Timing duration is now read from VSA file instead of a hard-coded 33ms.
-- bug (gil) Corrected VSA import issue when there are inactive tracks mixed in with active tracks. Fixes #1190.
-- bug (keith) Add in bulk edit for canvas mode
-- bug (keith) Fix bug which crashed house video export when writing last frame
-- bug (keith) Fix audio/video sync for some video files
-- bug (keith) Fix crash due to some GIF files where first frame was not the full frame size. Include support for GIF backgrounds
-- bug (keith) Fix check sequence Canvas mode checks
-- enh (keith) Add Y offset to wave effect
-- bug (keith) Fix square wave to make it recognise thickness and mirror properties
-- bug (keith) Fix strobe and meteors incorrectly drawing when responding to music but no music present
-- bug (keith) Fix Add DDP not disabled when outputting to lights
-- bug (keith) Fix align models does not save positions correctly.
-- bug (keith) Fix audio frame data not always prepared correctly leading to audio dependent effects not working as expected
-- enh (keith) Add MIDI scan to setup of MIDI triggered events in xSchedule
-- bug (scott) Fix crash if new group name is blank
-- bug (cjd) Revert to GTK2 due to ongoing instability in GTK3/wxWidgets support
