Release 2018.6 xLights released
smeighan
4217 Greenfinch Dr CO 80126
2018.6 released. 11 enhancements, 7 bug fixes
If a line in the release notes has something you needed or desired, please thank that developer!
I have been out of town for a week so sorry for the delayed release.
Thanks to our great developers!
2018.6 Feb 06, 2018
-- enh (gil) Add LOR event to xSchedule which should work with the Input Pup board.
-- enh (gil) Update LOR events to work with multiple cards on one port.
-- bug (gil) Fix model list in layout freezing. Fixes #1090.
-- enh (gil) Don't draw DMX head beams as white when color is black unless in Layout.
-- bug (gil) Fix DMX Flood not drawing in correct location. Fixes #1092.
-- enh (dkulp) Bunch of updates to DDP output to allow future enhanced output to FPP
-- bug (dkulp) Fix some render issues and crashes that occur after making changes to setup tab
-- enh (scott) Add Effect Select Panel.
-- enh (keith) xSchedule will now stop at the end of the FSEQ if it is shorter than the audio file
-- bug (keith) Fix vendor model download only allows model to be used once
-- bug (keith) When layout panel first opened models wont select
-- bug (keith) Fix 172.17.*.* - 172.31.*.* ip addresses incorrectly reported as internet routable
-- enh (keith) When configuring screen map in xSchedule show the area being mapped
-- enh (keith) Increase Value Curve/Colour curve resolution from 40 to 100
-- enh (keith) Improve the speed of number aware sort
-- enh (keith) Rework the window frame model to allow it to go CW and CCW. This may break some existing models
-- enh (keith) Check sequence to detect effects dropped on strands, submodels and models with no nodes
-- bug (scott) Fixed FPP Connect USB Drive Upload
