Warning about 12vdc pixel strings and specified power ratings
Today I had a very good discussion with Lithgow Lights about the power requirements of 12vdc pixel strings compared to 5vdc pixel strings and that the specifications state 0.3watts for both 12vdc and 5vdc pixels
So if the stated power is 0.3watts for both 12v and 5v then the only thing that can be changed is the current going through the LED, so instead of putting 20mA through the LED they instead use around 10mA so they then get the same power used regardless
We will only use the Green LED as an example here in an RGB LED
Green - 20mA - 5V
total power dissapated: 104milliwatts
40mW through the resistor
64mW through the LED
Green - 20mA - 12V
total power dissapated: 252milliwatts
188mW through the resistor
Green - 10mA - 12 volts
total power dissapated: 131milliwatts
100mW through the resistor
31mW through the LED
But this can be incorrect and Lithgow Lights has a string that puts 20mA through the LED and this is measured, so effectively this string will draw nearly 2.5 x the power than what is stated and this can be very misleading. This will also explain why Lithgow Lights said that they ran very hot as there is a lot of heat energy being dissapated through the resistor.
So just a heads up for those using 12vdc pixel strings
So in summary if using 12vdc strings then it is best to actually measure the current drawn by the string as it appears the rated manufacturer specs may be incorrect and misleading which can make a huge difference in how many power supplies and the guage cable used.
