Gso125 said:Are you guys using Polar Capture for the visualization or just Light Factory. How are you guys setting up a show with music I haven't figured out how that works yet. I see how to schedule i just starting with it and im watching set up vids. I'm on fence with buying it I just wish there was some display videos out there. Also is there a way to do Text in a matrix with LF or is it one pixel at a time and make frames.
I've found on large fixture counts, mine was 6100 this year that when running cues directly the display will lag, my workaround has been to create one matrix with all fixtures and use this in layout view. Doesn't solve everything till you then run cues from the cuelist playback screen, at this point the "preview" in the layout window is spot on.whyrl said:I know I'm a bit late to this conversation, but I'm the lead designer on the big CT display and I wanted to make a couple of points from my read of this....
1> On Screen display & Lag... Yes it is true the with LF the on screen display does not keep sync with the actual DMX output. It is not ideal for those of us who would like to use the screen as visualizer when programming in sync to the music. However, the performance to price ratio is most acceptable compared to the other big lighting desk software out there. (not that your considering a $100K whole hog or Grand MA lighting desk for your lightshow!)
That's largely the way i have used it and you can create some great effects, the other way is to use short motion loops with a static matrix effect.whyrl said:2>I think that LF is as powerful as Madrix, but it requires a bit more work to get the same effects. I actually consider this an advantage because I'm not going to use the "canned" effects that everyone else is, because I have to create the effect. But with some VERY VERY Simple images and graphics in combination with a matrix effect, and you can do some amazing things! And 90% of the effects in the CT show are just Matrix grids that move across an image. The sparkle effect at the end is just a black and white image that the matrix moves across.
Not fixed as of the 213 beta i used this year but i used this as a feature to enable a swipe around the megatrees from on to offwhyrl said:3> A little known "glitch" with LF is that if you rotate a matrix in an effect and the matrix is not a square, it will cut off parts of the image as it rotates. The simple fix is to create a matrix that has square proportions, but only use the cells that you need to for your grid. (leave the un-needed parts blank and this tricks the "engine" into thinking you have a square grid) (This *MIGHT* have been fixed in a recent release - I know it was on the list of things to get fixed, however it might also be part of LF3.)
Ah now something i didn't know, thanks for thatwhyrl said:4> Matrix import/export - it is very easy to create grids of numbers in excel. And it is very easy to import/export the matrix grids from LF. Easy to change your start address and have everything auto-shift in excel with some simple formulas - and then import. Easy to create a new matrix with a different layout. In fact the star in our CT show is driven by three different matrix layouts during the show. If it's easier to create an effect with a different layout, make one... It's great to be able to drive the same elements in different ways.
love this ability and feature and only really started to get around it this yerwhyrl said:5> Chases & copies of chases. There are really powerful tools in the FX editor to remove channels/attributes from a chase and also increase or decrease the value of a color in a chase. So I can create a chase in white and then copy it and make it red. copy the white again and make it green, copy the white again and make blue. I can make a chase that only affects the "dimmer" of an RGB pixel, so I can set the color in the cue and then run a chase that dims that color up and down. Or I can have a separate chase controlling the colors while a 2nd chase controls the brightness....
5b> Chase & Offset Copy chases - create a chase on one set of channels (say a 10 channel arch chase) and copy it with an OFFSET and then you have the same chase on your next arch. Now you can run those chases together in sycn, or in tandem... and you only had to create it one time. Combine this with the Remove channels and you can create many chases very quickly.
Oh this is absolutely brilliant and makes cue point setting a breeze, and i just learnt a trick that makes a library of cuelists easy and essential. Just create a new database, add the media FX, create new cue list, use visual editor to set all the cue points. Now open the production database and import the cue just created and in cue zero fire a media playback ro play the music and set all the cues up for what you want in the show. This leaves with and untouched but valid cuelist in the first db that can be reimported if needed.whyrl said:6> There is a new visual audio/timeline editor (I have not played with it yet). But It is designed to be able to make cuing shows synced to music very easy.
Oh yes and around 900Mb it will corrupt fully.whyrl said:6b> There is a new "dark" chase function - but I'm not sure if it is released yet, still in beta testing.
7> There is no "save" button in LF - As soon as you finish entering data, it is saved.
7B> The files get VERY large - there is a compact function to reduce the size of the database.
Options> System Properties> System Settings> Advanced Options> Make Show File Smaller.
Thank you for that, will try but i find the cue list loading to be the longest delay nowwhyrl said:8> If you have the Personal version, this may not apply, but if you want LF to load faster, remove the fixtures you don't use from the Library folder.
TOO TRUE!whyrl said:9> LF is one of the most actively developed pieces of software out there. And I can honestly say that Martin provides world class support. If you find a bug or crash the software, chances are it will be fixed with 24 hours (if not only hours). Not to mention that in three years of use, I have only lost my work once and that was because I was testing new features.
whyrl said:If you have other questions, I can try to answer them...
S
May be of use to others, the easiest way but maybe not the best is to create an image with the three colours and just move the matrix over the image.candlelight said:how would you create this effect??
on a mega tree, fade up from bottom white, then fade up from bottom red, then fade up from bottom blue
I tried creating a simple chase effect, and not adding the channels that I didn't want to change. but the chase effect seems to be all or nothing, if the channel is not included in the chase step, it turns it off. is this correct?
for instance, I removed the top half of the tree from my chase step, hoping it would leave whatever color was up there on, and then in the next chase step set those top channels to turn to red. but didn't seem to work that way..
any suggestions?
