BigRedNole
I am just starting to design for this year. I will be using mostly seed pixels. They are lighter, easier to store, and are definitely bright enough.
So, I started to piece together my first mini tree. 20 pixels per strand, 24 strands, and a 50 pixel star. I ran into several issues to start and figured I would share what I encountered/
- 5cm pixels have very little space for soldering and splicing. I found rejecting a pixel makes for best practice. Clip the end as close to the next pixel as possible and do the same on the other side. For my 50 pixel star, it works out to be 51 where the 51s pixel is sacrificed to leave 2" of wire on the ends.
 - Before soldering and messing around with the string, know the direction. I FUBAR's 50 pixels because of #1 and #2. Just twist the Xconnect and pixels together, test, and make sure the direction and pinout is correct. There is no real indication on my seed pixels other than a single gold wire indicates positive. Took messing up on the first string to learn how to identify.
 - Document your roll of seed pixels to know direction, which pigtail goes on which end, and follow it.
 - Count twice cut once. Almost screwed up the second set of 50 pixels by cutting at #50 instead of at #51.
 - When mounting to a prop (my star), make sure the pixels are facing out properly. The outer pixel were mounted backwards (facing in to the star). The inner pixels must have twisted and correct. I had to undo about 35 pixels and reseat them. I have a pixel tester and will use that before getting all the way through and then having to fix.
