Adding a Panel Matrix, using linsn reciever cards
SmartAlecLights
Murray Bridge, S.A.
This is the first hurdle,
Getting the panels to work directly off the pc without using an expensive sender card.
Im hoping this first video will help others in the configuration of the cards.
The Next Video will be for the Rasp Pi 3B+, Fpp setup, using the master/slave method.
Advantage of this method is your able to use a cheap receiver card designed to handle 256 x 256 pixels,
While using multi receiver cards to expand the display bigger
Your also able to use any Panel type P2,P4,P5,P6,P10,etc
You can also use the different Scanrates of the panels 1/4, 1/8, 1/16, etc
and last of all, all the different size's panel configurations 16x16, 16x32, 32x32, 64x32, etc
Just remember to ask for the .RCG file next time you buy your panels.
