Arch Fan wiring
deblen
Hi,
I have a Leaping Arch with with 7 fans, I am trying to work out how best to wire in xLights, but trying to use the pixels without splicing each fan.
I have tried going up and down using every second pixel, but does not look good when using an effect, you can seethe alternative pixel turn on.
Attached is a very rough diagram of the arch and fan.
Any suggestions grateful Deblen
Hi Katekate, thanks gives me something to use.
Deblen
Regardless of how it's wired, if you use different render buffers in xlights, you can probably get the look and effects you're after
