Bhrudwo
Beginner Question on different controllers and differential receivers
- Can you mix differential receivers from a single controller board?
- e.g. falcon board with a falcon smart receiver and a kulp receiver
- Or do they have to be brand to brand differential?
- Benefits of a differential setup out to a separate enclosure (smart receiver with separate power supply) over running a controller and power supply in the enclosure?
- Both setups would need comms (ethernet cable) and power run to the enclosure, so I am not understanding what one has over the other. Are differential receivers cheaper than a similar port controller board?
- Are Falcon and Baldrick the only locally available controllers?
- Wanting to go local for my first one or two controllers, and other bits, so I can source and talk locally
