Can you run two copies of visualiser
BundyRoy
I've had to create my display in two separate visualiser files due to the lor limitation on the number of elements. I have my 2d tree (900 pixels) in one and everything else in the other. I can run them separately to check my sequencing and it all looks fine.
When I start up two copies of visualiser to try and watch them both together only one works. I'm assuming this is to do with the network settings. Is there a way to get them both going so I can see the timing of one in relation to the other.
Technically this is not supported by LOR but yes it is possible.
Search for UDPSplitter on the LOR forum and you should find all you need to do this.
Regards
On that note I'm sure I've seen an option somewhere that would made visualiser come to the front when playing and I can't seem to find it again. Does anybody know where that option is.
