Cant get nutcracker to work???
ChrisB
Problem is something with wamp server. I downloaded it but i cant open it. Everytime i double click on pink desktop icon it pops up with do you allow this change to be made to your computer. I hit yes and it soesnt do anything. Tried running as administrator and still nothing. Any help would be appreciated. Chris
Start WAMP with "run as Administator" and see if that resolves the issue.
Also make sure its allowed though the firewall
Once it starts its should be sitting as a green icon in your system tray.
Then open a browser and go to http://localhost and you should see a web page appear. If this page comes up, WAMP is up and running and you can finish the install ..
Bob
Thanks for the reply, Ijust recently got that part figured out. Ive followed the rest of the instructions and i get to the part where i can create a login and password but it wont let me. Something about mysql or something like that. will be trying again in a minute. Chris
Well dont feel bad .. I'm having a few issues myself.
I cant get the install.php to complete without failing out. I may have picked up the wrong version of WAMP.. Mine fails at when creating the schema...
I'd be interested to know what version of WAMP you installed...
Bob
Thanks again for the reply. I can start the wamp server and local hot works fine. Under "your projects" there is actually a smeighan nutcracker version of the project. Clicking on it opens up a directory but i cannot create a password. Something about nc_user. How does one go about getting support for this software? Chris
Be sure to follow the order that i list
Nutcracker needs an Apache server and a MySql database running on your winodws (XP, 7) machine.
There are two choices for getting these, WAMP or XAMPP. I have used both.
Here are the steps to install Nutcracker on your local Windows 7 or Windows XP box
1) Download
Wampp. http://www.wampserver.com/en/
or
Xampp. http://sourceforge.net/projects/xampp/files/latest/download
2) Take all defaults for installation
3) Start Wamp. Click on the Pink W icon.
or
start Xampp and click Start for the Apache and Mysql applications.
4) Test Wamp or Xampp by setting your browser to http://localhost
if it is working, you will see the WAMP/XAMPP home page.
Apache server uses port 80. If you have Skype or microsoft HTTP/2.0 they also use port 80.
Here is a web page that describes how to fix this conflict. http://blog.techsoftsolutions.net/?p=315
For Wamp; the httpd.conf file is located in c:\wamp\bin\apache\apache2.2.22\conf directory
5) You now need to get a copy of the current Nutcracker code tree. Go to
http://smeighan.github.com/nutcracker/ and download the zip file. This file is updated daily with the latest Nutcracker code tree and with the latest export from meighan.net/nutcracker database
Unzip this file into c:\wamp\www\nutcracker if using WAMP
or
unzip it into c:\xampp\htdocs\nutcracker if you are using XAMPP
This zip file also now contains gnuplot so you dont need to install it separately.
6) Add gnuplot into Windows PATH environment variable.
I found a much better tool to do this and i have included the tool in the nutcracker zip file
WAMP:
Run c:\wamp\www\nutcracker\gnuplot\bin\PathEditor.exe as administrator
Add c:\wamp\www\nutcracker\gnuplot\bin
or
XAMPP:
Run c:\xampp\htdocs\nutcracker\gnuplot\bin\PathEditor.exe as administrator
Add c:\xampp\htdocs\nutcracker\gnuplot\bin
7) When you get Localhost working, install the database.
Enter http://localhost/nutcracker/install.php in a browser window
This command will do the following
a) Drop all the tables from your existing nutcracker database
b) create the nutcracker database if it is missing
c) create the nutcracker user: nc_user
d) execute nutcracker/sql/nutcrackertables.sql to create all nutcracker tables
e) execute nutcracker/sql/nutcrackerdata.sql to create 50,000 rows of data
MaterDaddy wrote this script for me, Thanks!!
Your local nutcracker should be ready
login in as
same login and password as you have always used.
