I am new to this and trying to use HLS and a PixLite 16 to controll my pixel strips.  I read the pdf and looked at the utube videos on configuring the output and everything looks good there.  I set the output to Ethernet, E131 and the IP address of my controller.  The Status shows green and I enabled the Active tab.  If I try to play my sequence now or even using the Test by Manually Turning Lights ON or OFF option I am not seeing anything.  I have enabled the Output Active tab.  What am I missing?  I think I have done everything as I should.  Any help would be appreciated.
