Yea, I think that may have been the issue I was having. But I do have to then set color order on the controller, I believe. Right?If you do it in string properties and set color order, I think it'll get done twice which is not good.
Or if it does not support colour reorder on a partial string (for multiple props on the same port or smart receivers on the same port), or if you don't know what controller will get the prop yet and don't have a setting because you added it to the layout and are going to figure out the wiring later, or...if your controller does not support colour reorder
