Colour differences in imported sequences
RolyT
I'm very lazy so have imported a few free sequences from here, XATW and others and when I preview on my house the colours are nothing like what is in the original videos. This happens on the house preview and also when outputting to physical lights.
I'm hoping that this is a quick fix or else it's been no point using pre- made sequences?
Anybody help please?
Your setup is different to the designer
The models and controllers should be RBG
But may be GRB BGR RGB
See what the string are set to and what your lights are set to
Well, color order would be the easiest way to explain the physical lights being off... but doesn't explain the house preview being wrong also. Do you have a link to your
1. Layout, or package up after you did import
2. Original sequence reference
3. Your .xmap that you used to make 1 from 2
Hopefully there's an obvious clue in one of those...
Can you explain what you mean about off? There are many different interpretations that could be used. Remember, in an investigation, details matter.
