GrantSimpson
- Jan 10, 2025
I manage a fleet of several hundred parade floats and many of those floats have multiple units (think of a train where you have the locomotive, passenger cars, and a caboose, each is a unit). Right now, they are all independent controllers each running their own xLights show. I am planning on tying all of the controllers together (adding a FPP player if needed) so I can run a synchronized show across the entire float and have effects run across the entire float. Is there a way to take multiple xLights shows (sequence and models) and combine them. I'm sure there would be a lot of clean-up work after the process with channel numbers and everything else, but it would likely be less than the work of re-creating the models and sequences from scratch.
