Copying and pasting effects in Xlights
spaulgal
Hi I have a bunch of perimeters set on a morph effect. Can i copy and paste the effect to another model? It doesn't seem to be letting me.
Also, can effects be stacked in xlights like they can be in vixen?
Yes, you can, just highlight the effect, hit Ctrl/Cmd-C and then select your insertion point, and press Ctrl/Cmd-V
For the second part, right click the model and add new layers (above or below the existing). This will then let you stack effects.
You can then play with the blending options to set how the effects interact with each other.
Thank you!
Are there a way to paste to replace a current effect (retaining the In and out points)?
