a little confused about hooking up 12 volts power supply to each bank on the board looked at the manual but still uncertain as what to do so the first power supply is hooked up to p13 ground and positive and the next power supply is hooked up to poo ground and positive I think this part is right? and the K1 is hooked up V1 - POSITIVE------ VO-and +5 are joined by a jumper and ground is ground my question is where does the positive V1 red wire come from and the ground also on the K1 thank you
