ecg-p2 lsp question
xyamom
hello i just had some question with ecg-p2 setup in lsp, I tryed changing settings around a little but i think im missing something up, (display is cut off ect at 170 pixles)
display info: ecg output
p1: 5x68 upper matrix and 5x34 garage matrix
p2: 5x96 lower martix
https://www.youtube.com/watch?v=h-_NlqloepA
^this is sample video with Davids test program and was having an issues with dual power supplies but fixed that with a capacitor (rgb looking static)
The issue i see here is that you have in the E1.31 output app set each universe to be 512 channels, now this doesnt divide correctly into 170 pixels. So you have an overlap as you should have the universes set for 510 instead and then the second universe starting at 511.
Im not sure if this is the issue but it definetly doesnt look right as you have 2 channels overlapping at the end of the universe as you have the e1.31 app set for 512 channels whilst the P2 config is set for 170 pixels (510 channels)
Worth a try anyway
Yes that worked, so be sure to create your universe as 510 channels and not 512 channels when setting up LSP or Vixen when using a ECG-P2 controller
