ELOR
ShayneT
Florida
Can a ELOR drive P12R? If so how would you split the 4 universes to the 12 output?
You can use the P12R with an ELOR but the answer is why would you bother as you only can only output 4 universes to a 12 universe controller. If you wanted to split those 4 universes over the 12 outputs then you will have set in the P12R configuration the correct universes and channel ranges for the appropriate outputs
