Error Message on running xlights
Dreamin
Sunshine Coast
Hi Everyone,
I've been getting these error messages in imported sequences sometimes. The only thing I can think of is that the number of folders is the issue but that's hard to fix as I keep them under my home folder in imported. If I select Ok, I can load that sequence perfectly fine, the error about copying the file only comes up at the start so it's purely just an annoying thing.
I do keep my files in onedrive, so I'm not sure if it's a onedrive message and it just says error on the box.
View: https://www.dropbox.com/s/d5hxrh9fo8n4hti/2021-08-02.png?dl=0
Any help appreciated.
Windows has a maximum path length of 260 characters. At a rough guesstimate I reckon that you would be around that. Try dumping the stuff into a new folder c:\xlights and then renaming a few things after you get it going.
Thanks mate, I'll give it a crack. I thought that might be it.
  • Like
Reactions: AAH
