spaulgal
- Oct 14, 2022
Hi I'm running two SRx1 V4.00 receivers off an F16v5 and am having an issue with one of them. The receiver in question will run fine for approx 60 seconds in test mode or running a sequence. After about 60 seconds, the red LEDs above each pixel output will light up and the pixels will shut off. If I reset the receiver board it will run for about 60 more seconds and shut down again in the same fashion.
I tested the voltage off the PS and am getting about 12 (as expected) and am getting about 8-12v at the receiver input. I cannot find a manual or spec sheet so I'm unsure what the red LEDs mean, but I imagine it's some type of safety mode.
Any insight would be appreciated.
Thanks.
Thanks.
