BigRedNole
I received my partial order of seed pixels yesterday from Ray Wu. They were a custom 240 string at 5cm with XConnect. I ordered a total of 12. Its almost 3000 pixels and they would store in a shoebox. That is what got me into looking at restarting pixels on my house. These were bought to make 5 or 6 mini trees and storage will be very simple with relatively easy setup each year (storage was the main reason stopping).
Fastforward to today where I started just testing with them. Stripped out all the old outputs from the F16v3, make a nice clean input for just Channel 1, and run some tests. Well, Test fails from the webpage. Only the first 50 lights lit up. I know, you have to set the number of pixels, etc. I did that and still didn't work. I will need to flash to the latest firmware. So, I went into XLights, wiped out the old layout, and started testing there. Everything worked as expected. The entire set of 240 lit up without issue. Updated the Channel to 480 pixels, created a power injection expecting it not get all pixels, and all lit up without issue. Changed the setting to 720 pixels, tested 3 sets expecting an issue, and they all powered up. It stopped at 720 though. I could not get the 4th set going at 960 pixels without power injection.
All 12 sets lit up without issues testing to be sure they all worked. I was surprised at how many were able to be powered by 12V. Take into account, there was no real distance from the controller either. I plugged in right at the pigtail. But even if there was some voltage drop for distance it wouldn't be much and tapping in at the 3rd or forth set as necessary would not be a problem. I am very excited about getting this started and ready to put up in October.
