there has been no models or pixels sent to the falcon from xlights, all outputs on the falcon have 0 pixels setup
are youy visualiing the outputs then uploading ?
That screenshot clearly shows 100 pixels per output. Nothing has been sent from xLights but that's completely irrelevant for test mode to work, as long as configuration is here, which it is.there has been no models or pixels sent to the falcon from xlights, all outputs on the falcon have 0 pixels setup
That's totally irrelevant to the discussion at hand. Here we are talking that it's not even working in test mode. The poster is trying to get pixels to light up using just the controller.Yoy have all outputs set as channel 1-100 for 300 channels
Xlights would need the second port sent to 301as the start channel
Getting that working is unrelated to the sequencer application or its configuration. It could be xLights, vixen, or even a lighting desk, at this point, nothing is feeding the controller data, it's generating it's own pixel data.ve got a falcon controller v5 and connected up controller and trying to use the onboard test function
xLights uses channel numbers internally ad to generate the FSEQ data. That's where it stopsXlights uses start channels and pixel numbers not universes ,
The difference in efficiency doesn't matter to most people's shows.Also set it to DDP as e131 is not as efficient
