Falcon Smart receiver
flash11
I have a Falcon smart receiver that has stopped working. It failed last night and has the data and power LED's flashing. I have swapped it out to another power supply and still no luck. Any way of fixing it? What could be the potential causes?
I had something similiar happen to me last season. It's more than likely in need of replacing rather than repair.
If the falcon isn't available locally, depending on your use case, the other brands receivers are often compatible eg. Hanson.
Have you tried swapping out the network cable? With the power led flashing that may not be it but have had a number of issues with network cables on these before
Also, try a different receiver port, If possible go from the board to board without using any pass thru connectors to see if there is any difference. I've had rj45 glands go bad before.
