Falcon SRx4 Help - Save my sanity.
Geraldton
This is driving me nuts, and I am sure it's something simple I am missing! Hopefully someone here can spot where I am going wrong. Full disclosure, this is my first Christmas using an expansion/receiver. Up until this year I have just had everything running straight into the controllers so all new ground for me.
I have a SRx4 connected to a Falcon F16v4 through a differential expansion board (ribbon connected). SRx4 is set to A on the rotary selector and the terminators are set to 'on' since there is nothing else connected after the SRx4. As I understand it the SRx4 is seen as 4 expansion boards and by setting the rotary to A I should be getting A, B, C, D with 4 ports on each.
Config on the controller is shown in the pic. Nothing setup in xlights yet as I am making sure it all works first.
All 16 ports on the SRx4 work fine when I use the test button on the SRx4 board, but when I try and test from the controller software I can only get a response from the 4 'A' ports. It's like B, C, D don't exist, but the 4 A ports work great.
Any thoughts are appreciated.
