Hi,
I am in the final stages of setting up my Mega Tree but I am having issues between xlights and FPP which I am sure must be a setting error on my behalf.
The FPP is set up so I can see it on my network and access the Falcon F16V3 connected to it, so I am assuming that is correct, lights will run a test sequence via either the FPP or the Falcon.
If I try and load a sequence via Xlights using the FPP Connect I get no light output although the sound plays through the FPP, checking the Channel Outputs shows the output as the FPP, ie Description, Output Type (DDP Raw) and IP as the FPP IP address.
If I manually set the Channel Outputs to E1.31 and match the IP to the Falcon, then through File Manager upload the .fseq files and the audio files the sequence plays.
I running the latest version of FPP and xlights
