Group Models Issue or Bug?
BrianZ
Miami, Fl.
Hello all. I’m having issues with my icicle group lighting all the pixels. Individually, all the icicles works fine. But when I put them in a group, some of the nodes Don’t come turn on, on each of the strings. All the strings are correctly networked in the falcon controller and like I said, they all turn when sequencing them individually, but not when they’re a part of a group.
So, you create a sequence and turn them all on individually, play it on the controller and it works.
You then create a sequence and turn on the group and they all do not light up?
Have you run tools - check sequence to see what errors are reported?
How are they all not lighting up?
Is your group higher in the list then the individual icicles?
Are all the icicles in the group?
So, let's take a look at how you have the group setup.
Screen shots help.
Screen shots help.
Hey Indi, exactly what you said in your first paragraph, is what’s happening. But I haven’t run the tools. I’ll work on that and report back.
I put the icicle group on the top of the other models, on the bottom and same. Just some of the lights turn on, on all the strings. Individually, they all turn on. Weird.
