Hi,
This is will be my first attempt at setting up a light show this year and I am reaching out to see if anyone has some good links or tips for doing the calculations prior to ordering and install. Apologies if this is a long read but I appreciate any help.
My current plan is:
Roofline:
18m 12V WS2811 30 LED/m strip
540 LEDs
180 controlled zones
Arches:
4 x 2.5m 12V WS2811 30 LED/m strip
300 LED’s
100 controlled zones
Pixel Props:
5 x 100 WS2811 12V resistor pixels.
500 LEDs
500 controlled zones
As for the arches I am tossing up between 30 and 60 LED per meter. I have read 30 is fine in 32mm airseeder tubing and I like the idea that the roofline and arches are the same strip to have better spares available. But I am considering using 60 led/m for the arches for added definition (this may be lost in the dispersion of the tubing though…) as the arches will be a main feature of my display.
Proposed layout:
![1715925730811.png 1715925730811.png](https://auschristmaslighting.com/data/attachments/19/19303-fafdcaf53b11a11710db2784bff66ab9.jpg)
Planned Controller:
I am planning on using a raspberry Pi 4B 4gb which I already have and running FPP and using a Hanson Electronics RPI-28D+ cap. This will give me 2 controller outputs for the WS2811 with the option for 4 with the FPP license key. I would plan to run 1 port for the roofline and then 1 port for the props and arches totaling 2 controller output ports for the show. As for the lawn props I plan to link them all together which would mean I only need to do a big control cable run to the first prop with the other runs only being between props that are next to each other.
Power Supplies:
For power supplies I am planning to go with the Aliexpress versions of the meanwells initially for the 12V supplies. I can have power sources on the left side of the house and in the carport on the right. Ideally I would like the controller to live on the right side under the carport and run cables out from there. I would be interested to know if these cable runs will be too long in practicality and the controller needs to be moved to get the signal closer to the props. I feel I can mitigate any of these issues with a booster like a false pixel mid way if required. There may be an impact of voltage drop over the power wires but I am happy to size up the copper within reason.
Now for the bit about calculations. How much power will I need and how many PSU’s.
I have read that 12V WS2811 resistor pixels consume about 0.72 Watts on 100% and white and that 12V WS2811 30 LED/m strips consume about 9W per meter.
Roofline = 18 * 9 =162W
Arches = 10 * 9 = 90W
Props = 500 * 0.72 = 360W
Total = 612W (I feel this is too high and in reality would be less?)
So I plan to power the roofline from both ends to mitigate any colour loss from voltage drop. I know we need both psu’s to be connected by ground but I read that we can’t have the lives connected unless we spec for expensive PSU’s built for this. Does this mean halfway through the strip I need to break the positive connection on the strip to keep the two PSU’s power source independent on the live line?
![1715925784183.png 1715925784183.png](https://auschristmaslighting.com/data/attachments/19/19304-bb649df7364e876cc5e702bf4b074e32.jpg)
Also noting that I won’t be running the display on 100% brightness, I read something in the range of 30 – 50% is more appropriate but I assume the power usage it not linear and it would not be half the number of watts?
Ideally I want to run everything from the right side of the house for power (expect the left side of the roofline strip) as this is more convenient. But I am not opposed to running power to the left side of the arches from the left of the house.
How many wires can I run out of my PSU, as many as there are terminals available for? In terms of wattage is it a case of as long as its under 80% of the PSU’s watt capacity it is all good (given a aliexpress PSU… I only want to use 80% of what it is ‘rated’ at).
What do people think, Would I be okay with 2 12V 350W PSU’s one on the left and one on the right? Or would I need 3 with 2 being used to power from the right side?
I am starting to think now that I should have 2 PSU’s the left powering half the roofline and the arches, and the right powering half the roofline and the props but the right might need to be more than 350W to comfortably power everything.
Now for running the power cables and the power injection. With 16 AWG wire at 12V over approx. 5 meters I’m hoping that this would be sufficient. If anyone has some good rules of thumb for this on how much voltage drop you can get away with for 12V ws2811 I would love to know.
Also regarding fuses, the inputs to the LED’s will be protected initially by the fuses on the Pi cap. I also want to use fuses on the input power to the Pi cap from the PSU and fuses on all power injection lines coming out from the PSU’s to the middle of the LED runs. Is there a good way to determine what fuse rating to use?
Enclosures:
How do people deal with heat dissipation in waterproof PSU enclosures. The 350W PSU’s come with a fan but how do we get airflow through the sealed box, are there some fancy air vents people use or does a roomy waterproof box have enough air to keep things safe? Does anyone have some good rules of thumb on boxes to use for controllers and PSU’s?
In short if anyone has some good links or rules of thumb to help calculate the number of PSU’s required prior to purchasing and install that would be great. Also any theory on how to correctly do fuses and the sizing of wires would be great to know! Any tips in general would also be very welcome! I am looking forward to playing around with lights this year.
Thanks for reading![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
My current plan is:
Roofline:
540 LEDs
Arches:
300 LED’s
Pixel Props:
500 LEDs
Proposed layout:
Planned Controller:
Power Supplies:
Enclosures:
Thanks for reading
