HC-1 card (75), I have a panel P10 32x16 HUB 75
Miguel
Hola, alguien que me ayude con un problema que tengo con una tarjeta HC-1 (75), tengo un panel P10 32x16 hub75 uso el programa FLASH LED o el HC-18.01, lo que sucede es que puse las medidas en el Programo todo cuando lo paso a mi usb y lo pongo en el cartel. Falto en las mediciones, no sé qué hacer con alguien que me ayude, por favor.
Google Translate into English
Hello, someone to help me with a problem that I have with an HC-1 card (75), I have a panel P10 32x16 hub75 use the FLASH LED program or the HC-18.01, what happens is that I put the measurements in the Program all when I pass it to my usb and I put it on the poster. I miss the measurements, I do not know what to do with someone to help me, please
if thanks for answering if I select them look so I put it like this in the photo
when I put the usb to my sign it is like that, it is supposed that the ok should come out full but I understand it like this, and when I take it out the letter comes out like this I put the H to guide me I do not understand why I get this way
friend, I did what you said I kept it in my USB but it came out this is the first time I get it
PANEL CONFIGURATION
