Help with setting up a Nikon D610 to record my show
AussieDoug
Just wondering if any of the camera gurus out there have used a Nikon D610 to record their show, if so what settings am I wanting to aim at using?
Thanks in advance
Doug
HELLO
First things first put your camera on a tripod. if you want to do video put it in Aperture mode use the lowest f stop you can iso put it on 1600 this should get you going then just play with the settings and see how you go
[SIZE=medium]I have a Nikon D90, but I must admit I haven't recorded the lights, just taken photos. I can't push the ISO very high, I'm limited to 1000 before noise becomes a problem. Hopefully you don't run into this issue.[/SIZE]
[/size]
[/size][SIZE=medium]http://auschristmaslighting.com/forums/index.php/topic,5304.msg45428.html#msg45428[/SIZE]
[/size][SIZE=medium]David is a great photographer, here's some tips from him. I believe he uses Nikon gear too.[/SIZE]
[/size][SIZE=medium] [/SIZE]
