Horizontal matrix
vincerules
I have my matrix made and added into nutcracker. It starts in the top right and goes like this:
I tried to do text in nutcracker(from left to right) and rows 1,3,5,7 all start/go the correct direction but rows 2,4,6 start on the left side and move right instead. How do I tell nutcracker that my matrix wraps the way it is above?
edit: Just wanted to add that everything works fine in the Test tab. If I do rgb cycle it goes through each pixel correctly.
you need a model that is
1) horizontal
2) starts wrapping in upper right corner
3) has two strands (folds) per string
thanks
sean
Thanks Sean, I'll try that out later today.
My matrix is 14 rows of 90 pixels each, so I should do:
Actual # of Strings: 7
# of RGB nodes per string: 180
# of Strands per string: 2
Starting Corner: Top Right
What if I had an odd number of rows, like 15?
14 rows of 90 pixels, is this 14 strings (You have 14 connectors)?
or do you have 7 strings of 180 pixels?
when we prompt you for number of strings think how many connectors you have.
if you have 7x180 strings then you would enter
strings? 7
nodes per string? 180
strands per string? 2
starting corner? Top right
Yes, I have 14 connectors. Last night I tried
# of Strings: 14
# of RGB Nodes: 90
# Strands per string: 2
and it gave me rows only 45 pixels wide...im guessing because the 2 "folds" would cause it to be folder in half... so what I need is 14 rows of 90 pixels, thats why i figured I should try 7x180/2 folds
Here is my raw setup without my confusing interpetations :)
I have 14 individual strings each with 90 pixels
90-----------------------1
91-----------------------180
270----------------------181
etc etc
# of Strings: 14
# of RGB Nodes: 90
etc etc
you need 14
90
1
14,90,1 makes a matrix in nutcracker that goes like this
90---------------1
180-------------91
270------------181
Some more info that I left out. I am running this off a p2. So 7 rows are on one port and 7 on the other. I think that is where I am screwed up.
So should I have 2 strings of 630 with 7 folds. I'll try that when I get home
90---------------1
180-------------91
270------------181
ok, i see. i am not sure why you wrapped them that way. 14 individual strings, the odd strngs you wrapped right to left, the even strings you wrapped left to right. We dont have a model that matches this.
i think you need to do what you were trying
7 strings of 180 nodes with 2 strands per string. that should get the channel layout in the right place.
thanks
Thanks Sean, I got it going. I misunderstood how the program wanted the settings. I understand now.
I am using a p2 for my matrix which allows 4 universes per port. So it should be 2 strings, 630 pixels 7 folds. But nutcracker only allows a Max of 300 pixels. I ended up using 7/180/2 to make it work.
Thanks again for your help.
