Fing
Hi,
There was a discussion on chat the other night about drilling plastic. Here is what i've been using successfully for years.
Find some "Wood bit Drills" these are also called sheet metal bits, they are like a twist drill but have a raised cutting edge on the outside so they behave like a hole saw.[attachimg=3]
They will also cut a round hole instead of a oval in thin metals. They are used in wood work because they don't splinter the timber.
I've also had success in drilling 20mm holes in 3mm perspex using a speed bit, once again with the raised outer edge.[SIZE=78%][attachimg=2][/SIZE]
cheers
Fing
cheers
Fing
