smeighan
Here is a short video tutorial that will explain the process of being able to enter timing marks into a file without having to go through the GUI. I find it faster when I am i am reading timing marks from Audacity and loading them into Nutcracker
https://vimeo.com/69479085
One thing i forgot to mention in the video, spaces and new lines can be in any order. I find if i make a file with one line per row, it goes the fastest.
For example, using the video's example of 3 models per timing mark
<tr><td>11.5</td> <td></td> <td></td> <td></td> <td></td> </tr>
instead of
<tr>
<td>11.5</td>
<td></td>
<td></td>
<td></td>
<td></td>
</tr>
So I would edit the file and add say 20 new lines
Now i go through and edit the old value of 11.5 seconds and put in what i really want. makes editing very fast. Save the xml file and reopen it in xLights and you will see all the new rows show up.
As I mentioned in the video, i will be building some utilities to help do this for you. I am not sure if i get it done before the Academy July 12th.
thanks
sean
instead of
<tr>
<td>11.5</td>
<td></td>
<td></td>
<td></td>
<td></td>
</tr>
thanks
sean
