Issue connecting to FPP with wifi only when sequences are playing, it works fine when nothing in running
striker72
Has anyone else seen anIssue connecting to FPP with wifi only when sequences are playing, it works fine when nothing is playing in FPP player. I confirmed this as soon as I start a new sequence over wifi, i lose the ability to connect to FPP. As soon as it's done, after a minute or so I can connect with no issues. It's very weird. I also cannot ping the FPP player when playing a sequence now. Never had this issue with older versions installed on this Pi. Thanks for the help. Open to any suggestions. I upgraded to latest
version of 7 but have not updated to version 8 yet.
FPP Version: | 7.5-6-g72ca6d6b
Platform: | Raspberry Pi (Pi 3 Model B)
FPP OS Build: | v2023-12
OS Version: | Raspbian GNU/Linux 11 (bullseye)
Are you running the sequnce from xlights or from a Pi or similar.
I can connect to my FPP player via wifi which is on a Pi when a sequnce is playing, - contol volume and stop start and change the sequence. But if you are running the sequence from xlights it is not possible.
