LED Panels From J1Sys
j1sys
There are no rules, and those are the rules.
Knoxville TN USA
I know it is late, but if you want to add some last minute pizzazz to your show take a look at some of our new products.
LED-C9 - a circular/starburst panel array of 51 WS2812B pixels. The board is 8.5in x 8.5in with 1in spacing between concentric circles. The board operates on 5VDC and includes optional differential inputs and outputs to allow long distances between the board and the controller as well as between daisy chained boards. Optional DC-DC converter can be installed to operate from a nominal 24VDC power supply over our standard PPX style Cat 5 cable.
LED-M7X7 - a rectangular panel array of 49 WS2812B pixels. The board is 6.5in x 6.5in with 1in spacing between pixels. Same specs as LED-C9 for power and signaling.
Also available are LED-C9HD and LED-M7X7HD with the same layout but the LED spacing has been reduced to 0.5in.
Limited stock, email for quote. Boards are IP00. They are bare boards and will either need to be kept inside or enclosed in plexiglass or something by the user.
Attached are a photo of all four boards showing a test pattern from a P12S. I like to call it the galaxy photo. Also individual non-lit photos of the C9 and M7X7.
Also below is a link to a high def video that shows all 4 in test pattern mode. they are doing simple R, G, B tests but they are all individual addressable pixels and can be driven in a myriad of patterns.
www.rabbit-electronics.com/image/LEDX4.MTS
TTFN
-Ed
photos of rear with optional DC-DC converter
