Hi guys and girls
I have a LOR DC board plugged into my Raspberry Pi via USB485 adaptor. the raspeberry Pi is running FPP. The lights work in test mode but i cannot get them to talk to xLights or run in a sequence.
You'll need to supply some more info and potentially screenshots.
Is it test mode in FPP that you have it working on or is there a test mode on the board? If it's in FPP then you have a fair portion of the setup done.
Assuming that it's in FPP that the test works and you're trying to control the board from Xlights while it's attached to FPP then you will have to configure the LOR board/dongle as an E1.31 output as you will be sending data via E1.31 to FPP. In FPP you will need to configure the "bridge universes" under the IO setup and put FPP into bridge mode.
Screenshots of the xlights network setup page and the fpp IO pages will definitely help.
