Road To Bethlehem
- Aug 8, 2024
I bought a couple of Baldrick Boards from Hanson Electronics. I can get them to work in some basic configurations, but nothing too advanced.
My scenario is a large number of pixels that slowly change. So a low frame rate is not a problem. Also I need to drive 1,000 pixels per port.
Firstly, the Baldrick Board manual says in relation to the Port Configuration, that one "should never have to play with this section." However, unless I create models with pixels, I get no output from xLights, and the test mode in the Baldrick Board web interface also gives no output. Am I missing something?
The Baldrick8 Introduction page states that the board has "an inbuilt test mode which gives a full colour wash to 2000 pixels just by long pressing the onboard buttons." Again, without defining models and pixels this doesn't work, and certainly doesn't illuminate up to 2000 pixels.
The problem with manually setting models and pixels is that I can only set a maximum of 750 pixels per port through the web interface.
Secondly, if I create a single straight line of 1,000 pixels in xLights (whether or not I have models and pixels defined), I get an error when visualising the controller which says: "Pixel port 1 has 1000 nodes allocated but maximum is 750"
How can I get the Baldrick Board to address 1000 pixels?
