$4 worth of materials.
Just two drain water push caps these are 90mm
5x pixel modules.
Hot glue the modules to the cap, hot glue if you had a dead module is easy to break off if required.
Note how they are facing, means less soldering! You can't see it, but there is a hole in the middle, that means I can pull through the excess wire between then modules on 2 pairs.
I'm going to put the second cover on it, and seal all the holes.
Just a photo of it in action.
5x pixel modules.
