NECG-DP2
djohnson1810
I was playing with the NECG-DP2 last night along with the xlights test function. I am using Ray Wu's Technicolor WS2811 lights. I have the jumpers set for Two 3 wire single‐ended protocol.
My HTML Configuration is set to:
1A is setup for universe 1 (150 pixels) WS281x
2A is setup for universe 3 (50 pixels) WS281x
When I ran the test pattern A-B-C-ALL, one output did RGBW and the other did BGRW. If I put the strands together end to end then they blinked together but(50 still would go from RGBW to BGRW depending on the output I had them attached to.
I messed around with the tab within the HTML Config to change the order of the LED's from RGB to BGR but that did not seem to change anything.
Any ideas?
